Date/Time: Wed, 23 Sep 2026 20:31:56 +0000
Data on 2-computers
View Count: 1222
| [2015-07-31 22:31:44] |
| JayShea - Posts: 93 |
Hello I use Zaner (OEC) for actual trading. Trading happens on the PC. I'd like to monitor price action (but not trade) on a laptop 2-stories higher. If there's an additional cost for this, please tell me what it is as well as how to make this happen. Thanks JD |
| [2015-07-31 22:46:11] |
| User911705 - Posts: 89 |
Just use Teamviewer.com to remotely access your pc on the laptop. Been using this free service for years and it always works great. You can even access multiple monitors and reboot remotely if you want to.
| [2015-08-01 00:42:09] |
Sounds like the answer given in post #2 would be a good way to do this.
