Date/Time: Sun, 22 Dec 2024 02:50:35 +0000
Custom Study JBVS
View Count: 1022
[2015-07-31 15:08:39] |
markuz - Posts: 90 |
There used to be a custom study JBVS under study > add custom study that is no longer working. Is this still available?
[2015-07-31 18:42:50] |
We are not seeing this study.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-01 00:12:23
[2015-07-31 18:53:16] |
here is a picture of the error
custom_study_not_working.png / V - Attached On 2015-07-31 18:53:12 UTC - Size: 173 KB - 333 views |
[2015-08-01 00:39:21] |
OK we misunderstood. We thought you were referring to a User Contributed Study which we could not find, which actually this is but it is not in that list. It is in the list of Sierra Chart provided studies. That study has been renamed to "Jim Berg's Volatility System". Remove it from the chart and add it again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
