Date/Time: Tue, 15 Sep 2026 12:53:26 +0000
Numbers bars help
View Count: 1278
| [2015-07-31 13:42:24] |
| Sebastian_M - Posts: 70 |
Hi Support, I am using numbers bars, and I am trying to increase the size of the fonts in the numbers, or make them bold. I cannot find this, can you help please? If it is not a feature, then could it be added? Than you in advance. Sebastian Date Time Of Last Edit: 2015-07-31 22:03:31
| [2015-07-31 18:22:01] |
The font size can be adjusted for all of the numbers within Numbers Bars, but not individually other than at the last trade price in the last bar. Refer to the documentation here: Numbers Bars: Font Size and Style for Numbers Bars There are no plans to add this. There are numerous conditions which causes the coloring of numbers or the background, and those are always handled by coloring. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-07-31 19:12:12] |
Thank you for your reply, So I have a request: Would it be possible in the future to include this feature please? I have attached 2 images. Thankyou in advance. Sebastian Date Time Of Last Edit: 2015-07-31 22:03:15
| [2015-07-31 19:51:14] |
Anything is possible but we do not plan to offer this. It is not something which is commonly asked for and it has a lot of implementation details to it and possible complications.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-02 22:08:41
| [2015-07-31 22:02:57] |
OK, thanks. If you decide to persue it in the future, could you let me know please? Regards Sebastian |
| [2015-08-02 22:27:22] |
This is not possible for us to do. It is not something we keep track of. It would be best to ask us about this again several months from now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
