Date/Time: Sun, 22 Dec 2024 03:14:19 +0000
Candlestick Pattern
View Count: 1082
[2015-07-31 09:16:56] |
User90998 - Posts: 6 |
Hi! Can I create individual candlestick pattern of a single candle in the indicator "Candlestick pattern finder" or in another indicator. If i can't, how can i do it? Thanks! |
[2015-07-31 09:27:44] |
Do you mean your own custom candlestick pattern? A pattern consisting of a single candlestick, should not be a problem to program as a formula. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-31 10:32:01] |
Yes. How can i do it with the formula? Where can i programm it?
Date Time Of Last Edit: 2015-07-31 11:19:25
[2015-07-31 18:05:54] |
CustomIndicators - Posts: 126 |
Well, whats the candlestick pattern you want to use?
[2015-07-31 19:03:11] |
You can use the Color Bar Based on Alert Condition study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s252 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-01 18:46:24] |
I solved my problem. Thank you.
Date Time Of Last Edit: 2015-08-01 21:03:23
