Date/Time: Sun, 22 Dec 2024 03:05:28 +0000
Super trend indicator Alert
View Count: 1616
[2015-07-31 06:36:08] |
JRA - Posts: 97 |
I am trying to put an alert on the super trend indicator when there is touch of the high in a downtrend or the low on an uptrend and used the following formula "AND (H >= ID1.SG1,L <= ID1.SG1)" but doesn't work. Can someone pls help me out?
[2015-07-31 07:00:41] |
That formula will become TRUE if the Study Subgraph value is within the high to low range of a bar (assuming this is your intention). We verified this now. The formula does work properly.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-31 07:00:59
