Date/Time: Tue, 29 Sep 2026 19:27:41 +0000
DOM Bid/Ask Price Display
View Count: 1167
| [2015-07-31 01:50:48] |
| User920601 - Posts: 7 |
Hello, My DOM shows corn futures, for example, at two tenths price intervals (skipping .8 cents) but the instrument trades at quarter cent intervals. How can I rectify this? Thanks |
| [2015-07-31 02:43:35] |
What Trading service are you using and what is the exact symbol?
| [2015-07-31 11:18:28] |
| User72407 - Posts: 31 |
Infinity AT with TransAct Futures. Screenshot of ZCZ5. Works the same for ZWU5, ZSX5 and others. Note how the sequence skips .008 cents. Thanks |
| [2015-07-31 18:49:08] |
Please contact your broker for help with this because this is the TransAct trading software you are looking at. In the charts, the tick size for corn (ZC) is .0025. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-31 18:49:30
