Date/Time: Sun, 22 Dec 2024 03:32:29 +0000
charts not maintaining settings when symbol is changed
View Count: 833
[2015-07-31 00:07:48] |
User929392 - Posts: 11 |
From Changing the Symbol of a Chart: Introduction link] - [Top]
Using SC v.1251 with data from SC Historical Data. Changing symbols, my bar chart settings for Session Time and Trade DOM Scale Settings are not maintained, go to default. How to fix this? Thanks.
Within a chart you can change to a different symbol. This feature lets you change to any symbol in the chart and keep all the existing chart settings and studies the same. |
[2015-07-31 01:11:06] |
Refer to this section here about Session Times: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#SettingIntradaySessionTimes The range when using a Constant Range scale will be reset. This is normal. What the documentation states, is referring to hundreds of settings which do remain the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
