Date/Time: Sat, 21 Dec 2024 17:50:26 +0000
Number bar problem- Bid/Ask Minimum Volume Compare Threshold not working on ASK column
View Count: 1743
[2015-07-30 03:10:26] |
NumbersBars - Posts: 141 |
SierraChart version 1278 Referring to documentation, Bid/Ask Minimum Volume Compare Threshold: If the Bid and Ask Volumes that are being compared are both less than the threshold, then the compare is not performed. I noticed the setting only works for Bid colummn, but not Ask colummn. Please refer to the attached images. Background coloring is set as Diagonal Dominant Side. Image 1, threshold is set to 0 (disabled); Image 2, threshold is set to 762. Ask you can see, Bid column (Red columns) are filtered out correctly by the threshold 762, however, the setting has no effect to Ask column (Green columns). Please let me know if I have missed out something, or I do not understand the setting correctly. Date Time Of Last Edit: 2015-07-30 07:18:06
numberbar_threshold_pic1.png / V - Attached On 2015-07-30 03:08:51 UTC - Size: 136.71 KB - 522 views numberbar_threshold_pic2.png / V - Attached On 2015-07-30 03:09:03 UTC - Size: 167.15 KB - 519 views |
[2015-07-30 17:12:23] |
Hi Support, Do you have chance to look into this issue? Is this a bug? or setting problem? Thanks. |
[2015-07-30 17:26:07] |
Not yet. We will be getting to it as soon as possible.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-30 17:26:26
[2015-07-30 22:23:29] |
Al SC Developer - Posts: 434 |
This should be addressed in next version.
