Date/Time: Mon, 21 Sep 2026 18:24:15 +0000
OEC symbols
View Count: 1252
[2015-07-29 13:22:39]
User244592 - Posts: 49
I am using OEC and when loading symbols I occasionally get a symbol error message , though the data loads properly. At times these symbols that gave this message stop updating. If I disconnect, then reconnect it updates fine. At some later time it may need to be reconnected again. I am running S5 trader at the same time but not using the same symbol in both programs.
[2015-07-29 17:04:44]
Refer to this section here:
https://www.sierrachart.com/index.php?page=doc/openecry.php#SymbolLimit
You have gone over the OEC symbol limit.
