Date/Time: Sat, 23 Nov 2024 03:56:02 +0000
problem with historical data
View Count: 2494
[2013-06-11 01:49:15] |
M5amhan - Posts: 468 |
this is only happening with gold, it will not plot any of the prices correctly on today's daily bar (6/10/13) http://www.sierrachart.com/image.php?l=1370915234521.png here are the correct OHLC for the day: http://www.cmegroup.com/trading/metals/precious/gold_quotes_settlements_futures.html every time i go in and change the data (and save it on the notepad) it changes back when i restart sierra to make sure it stays |
[2013-06-11 05:28:54] |
Temporarily there might be incorrect data from our data provider. What you need to do is go to Edit >> Download Data-Historical Chart to re-download the data. Try again now and also tomorrow if you still see invalid values. When posting a chart, please post a very simple chart that consists of nothing more than chart bars and nothing else. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-11 05:29:32
[2013-06-11 05:50:06] |
http://www.sierrachart.com/image.php?l=1370929337542.png i will remember that they still havent fixed it, will check back tomorrow if needed thanks |
[2013-06-11 16:48:05] |
the big problem from this morning got fixed, so i decided to give it an hour or so to see if my initial problem got fixed and it still hasnt i tried editing the data and saving it but it wont save and i also tried edit > download data - historical chart that didnt work http://www.sierrachart.com/image.php?l=1370969161170.png |
[2013-06-11 21:58:22] |
can this please be resolved?
[2013-06-11 22:04:56] |
It is not clear what the problem is. Please be more precise about it.
[2013-06-11 22:17:51] |
the bar for 6/10/2013 is plotting incorrect data the attached picture is what the gold chart is plotting with a chart values window right next to it showing the OHLC for that day.. http://www.cmegroup.com/trading/metals/precious/gold_quotes_settlements_futures.html in the above link if you go back to yesterdays trade date and look at the "Aug 13" row, those are the correct OHLC for that bar. if i edit the data and save it, it will not stay in the corrected form after a reboot. and the download data - historical chart does not fix anything. i am thinking the problem is the data provider is not giving accurate OHLC for that day since that is what you told me, i just want the accurate data. thanks |
[2013-06-11 22:23:25] |
here is an attachment of what the gold data should be presenting in a visual form
[2013-06-11 22:26:43] |
OK we have forwarded this issue to our data provider.
[2013-06-11 22:31:19] |
Reply from them: The price correction for 6/10 is already in our system and will be corrected with tonights update.
[2013-06-12 23:42:07] |
gold did it again, these values are not accurate. this effects my pivots and how i make trade decisions http://www.sierrachart.com/image.php?l=1371079986503.png CME OHLC: http://www.cmegroup.com/trading/metals/precious/gold_quotes_settlements_futures.html |
GCcorrect.png / V - Attached On 2013-06-12 23:40:56 UTC - Size: 11.02 KB - 565 views |
[2013-06-14 14:48:11] |
[2013-06-14 18:05:15] |
We thought it would be resolved automatically by the data provider, but we will let them know.
[2013-06-14 18:07:05] |
What is the date of the incorrect data? While it may be clear to you, it is not to us.
[2013-06-14 18:11:21] |
me too, that is why i thought i should wait a few days before saying anything further.. the date is 06-12-13, it is included in both attached images in the values window. thank you for helping with this |
