Date/Time: Fri, 11 Sep 2026 03:52:06 +0000
PnL not displaying properly
View Count: 1653
[2015-07-27 20:23:17]
user30624700 - Posts: 5
I upgraded from 1241 to current version (1277). I set PnL to display as "Points - ignore quantity" but it still shows the total Pnl for all contracts traded (so shows same value as if it is set to "Points") on the DOM. I also tried a prev version 1269 but had same problem, reverting to 1241 is fine. Please advise.
[2015-07-27 23:45:46]
Other than the Open Profit/Loss value, the "Ignore" Profit/loss formatting methods are no longer supported. This is a permanent change because they cannot be calculated reliably in all cases.
