Date/Time: Wed, 14 Oct 2026 12:03:54 +0000
Can't connect!!! is this because I have do not have a data service? (message log included)
View Count: 1824
| [2015-07-27 19:37:41] |
| User371291 - Posts: 13 |
Hi there, I recently attempted to connect and got this message: "Rithmic Trading | Port for executable: 50373 | 2015-07-27 15:34:17
Listening socket (1432), port 50373 | Closed. | 2015-07-27 15:34:17 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-07-27 15:34:17 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50373 | 2015-07-27 15:34:19 Socket (106) | Connected. | 2015-07-27 15:34:19 Rithmic Trading | Connected to server. | 2015-07-27 15:34:19 Rithmic Trading | Sending logon request message. | 2015-07-27 15:34:19 Rithmic Trading | Starting the connection process to data and trading service. | 2015-07-27 15:34:19 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-07-27 15:34:19 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-07-27 15:34:19 Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-07-27 15:34:21 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2015-07-27 15:34:21 Rithmic Trading | Server Name: DTC Bridge. | 2015-07-27 15:34:21 Rithmic Trading | Server protocol version: 6. Client protocol version: 6. There is a protocol match. | 2015-07-27 15:34:21 Rithmic Trading | Logon error from server | 2015-07-27 15:34:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-07-27 15:34:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-07-27 15:34:21 Socket (106) | Shutdown and closed. | 2015-07-27 15:34:21 Rithmic Trading | Disconnected from the server. | 2015-07-27 15:34:21 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-07-27 15:34:21 Rithmic Trading | Bridge process is still running. | 2015-07-27 15:34:23 File >> Disconnect selected. | 2015-07-27 15:34:24 Rithmic Trading | Disconnected from the server. | 2015-07-27 15:34:24" I have not signed up with a Trading Service, could this be the issue? Thanks. |
| [2015-07-27 19:54:43] |
Do you have an active Rithmic demo or live account? If not, you will not be able to connect to the Rithmic system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-07-27 20:13:49] |
no I do not have a demo account, which providers offer demo accounts?
| [2015-07-27 23:45:01] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on.
| [2015-07-28 03:45:10] |
CME Emini ESU ESM |
| [2015-07-28 03:59:25] |
Is there a particular futures broker you are currently working with? If so, then contact them for a demo account. If not, then refer to this page: https://www.sierrachart.com/index.php?page=doc/links.php For the time being you can use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-28 19:25:20
| [2015-07-28 18:57:12] |
Hi Thanks for the great support. I have configured the DTS to 'SC Historical Data'. I am interested in attaining 1min, 30min, 60min, daily data for the ESU15 & ESM15 contracts. I didnot have much problem exporting data for the ESM15 contract. But am having difficulty getting the ESU chart to load: The daily ESU chart loads up, but when I click on 1min> its simply blank! Any solutions? Thank You. |
| [2015-07-28 19:27:23] |
ESU is not a valid symbol. You should not even have any historical daily data for it either.
| [2015-07-28 20:04:00] |
ESU15? the september contract? How is it not valid? isnt it the front month contract for the ES right now?
| [2015-07-28 20:06:43] |
also I am able to successfully view $TICK data on the 1min timeframe
| [2015-07-28 20:18:04] |
I have excluded the entire Sierra Charts folder on my malware program
| [2015-07-28 20:18:47] |
this is what the message log is saying: "Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU5-CME.scid | 2015-07-28 16:16:31"
| [2015-07-28 20:54:35] |
ESU5 is the symbol I was referring to
| [2015-07-28 21:47:29] |
ESU5-CME is not a valid symbol for the Sierra Chart Historical Data Service. You need to use ESU15 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-07-28 22:15:42] |
oh I should of known thank you! I found it when searching September contract |
| [2015-08-03 16:55:21] |
Hi there, Would you be able to explain to me how to bring up charts from 2014? ie ES 03-14 (or ESH14) I went to "Find symbol", and all it has is the 2015 & 2016 contracts. Thank You, Hupfield |
| [2015-08-03 17:04:07] |
Refer to the instructions here for this: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#h42.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-08-03 21:27:47] |
I exported historical data to a text file. I noticed in the timestamps that they are in "second" format: 20150624 000001;2117.5;2117.5;2117.5;2117.5;7
20150624 000002;2117.5;2117.5;2117.5;2117.5;5 20150624 000003;2117.5;2117.5;2117.5;2117.5;1 20150624 000005;2117.5;2117.5;2117.5;2117.5;2 20150624 000006;2117.5;2117.5;2117.5;2117.5;2 20150624 000007;2117.5;2117.5;2117.5;2117.5;35 20150624 000009;2117.5;2117.5;2117.5;2117.5;3 Is there any possible way that I could export data so that it will be in a minute timestamps? ie not show the seconds? Thanks |
| [2015-08-03 21:39:25] |
That is not Sierra Chart exported data you are showing. We cannot help with this.
