Date/Time: Sun, 27 Sep 2026 09:20:08 +0000
Volume by Price- Alerts
View Count: 1057
| [2015-07-27 15:39:11] |
| Moti - Posts: 63 |
Hello, i would like to build alert that active when Last or close of bar crosse above VAH or crosse below VAL. 1) What is the Subgraph SG for VAH & SG VAL ? 2) This can work as condition? ID1.SG VAH > ID1.SG VAH[-1] Thanks, Moti |
| [2015-07-27 17:53:35] |
Subgraph 3: Value Area High Subgraph 4: Value Area Low You can see this on the Subgraphs tab of the Study Settings window for the Volume by Price study. In the current versions of Sierra Chart you can reference this data with an Alert Condition Formula. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-27 17:53:54
