Date/Time: Mon, 27 Jan 2025 04:52:41 +0000
ChartDOM Grid
View Count: 1881
[2015-07-24 21:40:00]
QnReally - Posts: 181
Is it possible to add support for horizontal grid lines on the Chart DOM similar to the "TradeDOM Grid" option in the near future? Thanks.
[2016-11-08 18:01:06]
ticinotrader - Posts: 401
I have just searched for this feature (Chart DOM Grid). Do you have any update or plan to add this to Sierra? Thank you.
[2016-11-08 22:37:36]
The closest is the horizontal grid:
Chart Menu: Horizontal Grid (Chart menu)
[2018-07-19 14:10:32]
whats1thingnow - Posts: 407
same question as post #1 from 2015 - any chance this can be added?
[2018-12-12 22:32:42]
still looking for the horizontal grid on chart dom :)
don't want the lines on the chart itself... just the chart dom that's attached
possible?
[2018-12-13 07:07:52]
Try to set the horizontal grid's color to same as the chart background and in the meantime set a different color to the chart DOM's background.
This way the grid will show up on the Chart DOM only. See the screenshot below for an example:
http://www.sierrachart.com/image.php?Image=1544684702710.png
Date Time Of Last Edit: 2018-12-13 07:37:34
[2018-12-14 06:06:09]
@ticinotrader great looking dom and great idea :)
@support:
i'm not sure why my horizontal grid doesn't extend to the dom, enough though i have this option checked:
trade > chart dom settings - global > [check] extend chart horizontal grid onto chart dom
[2019-02-23 05:40:27]
for anyone else wondering how 'grid on dom only' is done:
chart > graphic settings >> change 'Chart Background' & 'Chart Grid' to same color (i.e. black)
chart > graphic settings >> enable & change 'Chart DOM Ask Background' and 'Chart DOM Bid Background' to same color (i.e. gray)
