Date/Time: Fri, 18 Oct 2024 06:16:55 +0000
Countdown timer is now showing on chart.
View Count: 1015
[2015-07-24 13:47:36] |
User48557 - Posts: 138 |
I am trying to put on a countdown timer on my 10 minute chart and nothing is showing up. What is going on ?
[2015-07-24 18:16:01] |
Open the Study Settings window for the Countdown Timer study and check all of the Inputs which control its position and verify they are correct. Here is the documentation for the study Inputs: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s201 Go to the Subgraphs tab of the Study Settings window for the Countdown Timer study and check the color settings to make sure the text foreground color is not set to the same as the chart background color. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
