Date/Time: Sun, 04 Oct 2026 04:41:06 +0000
Date Range in File?
View Count: 2287
| [2015-07-24 03:48:09] |
| peaceland - Posts: 95 |
Why is there so much difference when loading various Forex pairs? Some have LOTS of time, and others, like EU have very little data? Why? Is there a way to change the date range that is downloaded for specific pairs? Why don't they all download the same amount of data? thank you
| [2015-07-24 03:58:30] |
Why is NU: 2007-12-03 to 2015-07-23 GU is only: 2015-01-18 to 2015-07-23 What's up with that? |
| [2015-07-24 06:02:30] |
The symbols you are mentioning are stock symbols if these are literally what you are using within Sierra Chart.
| [2015-07-24 16:01:45] |
No, I mean NZDUSD and GBPUSD for forex. Why are the files so short for some of them (including EURUSD)? NZDUSD has a LOT more data, why don't the other files/pairs? Date Time Of Last Edit: 2015-07-24 18:27:56
| [2015-07-24 16:29:37] |
All 3 symbols (NZDUSD, GBPUSD, and EURUSD) have data starting from 2007-12-03. Follow the steps here to get more data: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#h42.1 Sierra Chart Support |
| [2015-07-24 18:15:00] |
But it says this for EURUSD no matter how man days I say to DL: 2014-02-26 to 2015-07-24 Is that because of intraday? But intraday on NZDUSD does not have the same date range. I'll do some screen shots this weekend. |
| [2015-07-24 18:28:55] |
We definitely do not need any screenshots. They will not help us and we would not look at those. Once again follow the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#h42.1 There is no doubt you are missing a step. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
