Date/Time: Fri, 18 Oct 2024 06:15:32 +0000
Same formula gives error on one machine and no error in a second machine
View Count: 697
[2015-07-23 23:06:41] |
CMG - Posts: 179 |
I have a simple alert formula =OR(SG1,SG2) on a study alerts tab, this is for a study that signals arrows long (sg1) or short (sg2). On the Alerts Manager the same formula on one machine works fine but in a different machine gives and error:#VALUE!. The machine that works is version 1241, the other machine is version 1275. What could be the problem? Thanks |
[2015-07-24 02:02:08] |
It needs to be written as: =OR(SG1 <> 0,SG2 <> 0) Each of the expressions needs to evaluate to a Boolean value. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
