Date/Time: Fri, 18 Oct 2024 06:15:59 +0000
ToolBar position problem
View Count: 846
[2015-07-23 09:26:15] |
User386687 - Posts: 53 |
I dragged the toolbar from the "main" window to above it (1st attached picture). Then I did "File Save All" and Exit but when I start the application again the toolbar is back to the "main" window (2nd attached picture). So it seems the toolbar does not remember it's position after restart. Am I doing something wrong ? Date Time Of Last Edit: 2015-07-23 09:28:10
2015-07-23_12-18-56.jpg / V - Attached On 2015-07-23 09:25:18 UTC - Size: 64.5 KB - 289 views 2015-07-23_12-19-48.jpg / V - Attached On 2015-07-23 09:25:32 UTC - Size: 49.42 KB - 277 views |
[2015-07-23 09:31:37] |
You are using the old Microsoft-based ToolBar. Update Sierra Chart to the latest release through the Help menu to use the new Control Bar. There will not be any problems with the new Control Bar like this. If so, please let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-23 09:32:15] |
tobi - Posts: 351 |
SC has been working on the Tool bars lately. Update to the latest release, that might solve the problem.
[2015-07-23 11:07:04] |
Oh yeah! Newest version works OK.
Date Time Of Last Edit: 2015-07-23 11:07:22
