Date/Time: Fri, 18 Oct 2024 06:15:59 +0000
compatibility of SC Real-Time data feed with Infinity Sierra charts edition
View Count: 2185
[2015-07-22 23:49:05] |
User428317 - Posts: 5 |
Hi support board, I am using sierra chart from Infinity broker with data from TransAct. However I would like to start using Sierra Chart Real-Time data feed directly from your company. Is there any way how can I keep using Infinity edition of their sierra charts and simply switch data feed to Sierra Chart Real-Time? Currently when I start Infinity Sierra charts edition using infinityAT platform there is only one choice for data feed which is named as "Service [trading]" and I am not able to change this field because it is grayed out. Thank you for your advise.
[2015-07-23 04:54:19] |
To use the Sierra Chart Real-time and Historical Exchange Data Feed requires a direct account. Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-23 13:18:47] |
Thank you. I would have one more question about using Sierra Chart Real-Time data feed with Infinity. This post (http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Integration) says this data feed is fully and seamlessly integrated also with Infinity. But as I realized for example Sierra Chart Real-Time data feed symbol for current e-mini Nasdaq is NQU15 and when I login into Infinity DOM it says only NQU5. I did not purchase the data yet, but if so, how this different symbol naming convention is treated SC real time data feed and InfinityAT platform which I believe is must to be turned on when I place trades through them. And also I would be interested if trade placed through sierra would be visible in Infinity AT DOM (and vise versa) if there is different naming in NQ symbol. Thank you very much.
[2015-07-23 18:25:58] |
When using the SC Exchange Data Feed the symbols you will use will always be what are listed in File >> Find Symbol. And also I would be interested if trade placed through sierra would be visible in Infinity AT DOM (and vise versa) if there is different naming in NQ symbol. Yes this will be the case. The symbols are the same.
