Date/Time: Fri, 18 Oct 2024 06:15:59 +0000
V1275 Odd screen behavior with trading dom
View Count: 790
[2015-07-22 22:02:55] |
ertrader - Posts: 670 |
Hi support...there is something odd with V1275. The trading dom should be pinned to the right. I'm going back to 1269 http://www.sierrachart.com/image.php?l=1437602439688.png Date Time Of Last Edit: 2015-07-22 22:03:24
[2015-07-22 22:07:29] |
This is what it should look like. This is from V1269 http://www.sierrachart.com/image.php?l=1437602870826.png Date Time Of Last Edit: 2015-07-22 22:10:17
[2015-07-22 22:12:52] |
We are checking on this.
[2015-07-22 23:04:32] |
We have duplicated the problem, solved it and we will have a new release out late this evening.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-22 23:04:53
