Date/Time: Mon, 28 Oct 2024 08:57:51 +0000
Option chains w/ IB
View Count: 1095
[2015-07-22 18:02:56] |
User713273 - Posts: 409 |
Hi- Just recently signed up for a free trial, I have to say quite impressed with the functionality thus far. Im currently using IB, could someone give me a quick rundown on how I would pull option chains for certain US equites? The whole process would be ideal as I havent yet delved into the automation process yet. Thx Adam |
[2015-07-22 18:16:29] |
Sierra Chart does not support option chains from any Data or Trading service. You will need to do this within Trader Workstation.
