Date/Time: Mon, 28 Oct 2024 08:57:51 +0000
spreadsheet question
View Count: 721
[2015-07-22 02:09:17] |
jaban - Posts: 66 |
Hi I try to make a spreadsheet showing the following: date - friday market close and next monday market open - points difference for each currency pair. Is this possible ? ( the copy formula function is inactive , on my system ) thks |
[2015-07-22 17:57:56] |
You will need to work out the details of the formula but to easily do this kind of calculation you need to use the Spreadsheet study on a Historical Daily chart. And you will need a separate chart for each currency pair. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-22 17:58:27
