Date/Time: Mon, 23 Dec 2024 03:17:41 +0000
sc.SetACSToolButtonText()
View Count: 821
[2015-07-21 16:44:51] |
QnReally - Posts: 181 |
sc.SetACSToolButtonText() function is not setting the button text in the Control Bar. It just shows the text "CS3", etc. Is this still being developed or is there a replacement function in ACSIL? Thanks.
[2015-07-21 18:10:05] |
This has not yet been developed in the latest prerelease.
[2015-09-11 03:14:20] |
User35525 - Posts: 181 |
Using 1294; is this still being developed? Thanks.
[2015-09-11 03:16:46] |
It should definitely be working in version 1294. Is it not working for you?
[2015-09-11 04:41:12] |
It isn't working for me, but was earlier last month. Maybe I have something misconfigured with the new control bar or CTV settings, or it's other user-error; I'll double-check my ACSIL tomorrow to make sure I'm using the correct tool bar. I'm also using wine 1.7 but I doubt it's a wine issue.
Date Time Of Last Edit: 2015-09-11 04:45:11
[2015-09-11 17:20:01] |
It was user-error. I had this line in the study: if (sc.IsFullRecalculation) return; This aborted the function before setting the button text with SetACSToolButtonText(); I needed to move the check for IsFullRecalculation() later in the study. :-) |
