Date/Time: Mon, 28 Oct 2024 08:57:52 +0000
Daily OHLC
View Count: 739
[2015-07-21 13:42:11] |
User228426 - Posts: 14 |
When using Daily OHLC Open (SG1) set to "0" Reference Days Back I am refreshing (Insert key) the chart to get rid of the previous days Open (SG1) which is set to Dash. Is there a way to show only the current day OHLC or do we have to refresh the chart to get rid of previous day?
[2015-07-21 18:43:11] |
We are not completely understanding this. When you notice the problem, post an image of the chart by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image You might want to set Number of Days to Calculate study input to 1. But that will not completely solve the problem the way you might want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-21 18:43:37
