Date/Time: Mon, 28 Oct 2024 08:57:52 +0000
vbp ticks per volume bar is not changing .
View Count: 1462
[2015-07-21 13:13:47] |
User48557 - Posts: 138 |
My settings are stuck at 5 "ticks per volume bar", It will not allow me to change the settings. What is the cause
[2015-07-21 18:27:59] |
Go to Chart >> Chart Settings and set the Volume at Price Multiplier to 1.
