Date/Time: Sat, 14 Nov 2026 05:11:41 +0000
Problem with Historical Data
View Count: 1204
[2015-07-21 10:37:54]
LukeScisl - Posts: 18
On my historical chart data I miss data from the period between 2013-09-11 and 2014-03-13
What could be the reason for this error?
http://www.sierrachart.com/image.php?l=1437474848777.png
[2015-07-21 11:01:54]
Update Sierra Chart to the latest release with Help >> Download Current Version. This is a critical step since you are using the Continuous Futures Contract feature.
Re-download the data following the instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading
Also do not use the volume-based Continuous Contract rollover setting for stock index futures. Use the Date Rule Rollover setting instead.
Date Time Of Last Edit: 2015-07-21 11:02:46
[2015-07-21 11:30:42]
It works,
thanks for fast reaction
Topic can be closed
