Date/Time: Fri, 18 Sep 2026 20:01:05 +0000
V1273 - Add custom study - not detecting existing Custom DLLs
View Count: 2381
[2015-07-29 03:49:25]
Try the latest prerelease. The version number is the same but we have made changes which solves all of this.
[2015-07-29 04:03:44]
ejtrader - Posts: 689
SC Team - Here is update on this
Issue 1 (missing dll/partial studies display) - resolved. Thank you very much for this.
Issue 2 (duplicate study name) remains (qt/g++ -not sure if this is the case with vs2013). this is not a priority. Would see if I can get a dll for this. Also would try to isolate the issue and see if there is any consistent pattern which introduces this issue.
For my current project(as well as couple of more projects) this issue is reproducible ( individual cpp works fine but when added to the existing library - it starts displaying duplicate and not all studies would be visible).
screencast.com/t/9dxy5qcp
Issue 3 - Atleast I know the reason it behaves like this. So this is pretty much a non-issue.
Probably few days - before I can come back to this thread. Issue 1 - was important for me to get fixed and you fixed it. thank you much.
thanks
Date Time Of Last Edit: 2015-07-29 04:16:44
[2015-07-29 05:12:37]
Even for Issue 2 - with some experiment - I have found a solution - though not very optimal - It's an acceptable solution.
Unless there are any other issues noticed - all these issues reported in this thread can be marked as "resolved".
thanks
Date Time Of Last Edit: 2015-07-29 05:13:39
[2015-07-29 06:08:21]
In regards to the duplicates, using the latest Sierra Chart revision of the prerelease do you see the duplicates with the DLL in post #21? You should not. That is what we tested.
[2015-07-29 06:18:46]
SC Team - Post#21 dll - didn't have duplicates to start with. It was provided related to issue 1 only ( studies being partially visible) - which is resolved.
For duplicates issue - I have found a non-optimal(but workable) solution with the latest pre-release. I would experiment further and confirm - what is actually introducing the duplicates issue.
[2015-07-29 06:37:43]
Here is the DLL(compiled with vs2013) and source that would introduce the duplicates issue. In case if you would like to check on this further.
Have put the comment in the code - how this duplicate issue is occurring.
Date Time Of Last Edit: 2015-07-29 06:41:26
Private File
Private File
[2015-07-29 09:37:27]
The compiled DLL in post #21 definitely has a duplicate. We can clearly see that.
[2015-07-29 10:20:24]
The problem in post #30 has been fixed. It does not relate to any new changes we made. This was a long-standing issue when the GraphName was not set.
[2015-07-29 13:48:19]
Thanks SC team.
For post#31 - as the studies were partially visible(at the time of upload) - I wasn't sure whether it has duplicates issue or not.
for post#32 - is the fix released already or would be released later?
Date Time Of Last Edit: 2015-07-29 13:48:41
[2015-07-29 17:28:19]
The latest change, has not yet been released.
