Date/Time: Sat, 23 Nov 2024 00:15:50 +0000
manually move multiple stop orders on chart
View Count: 2349
[2013-06-10 12:32:04]
cross - Posts: 70
Is it possible to move multiple stop lines on a chart which are in different OCO of the same trade and apparently fit to the same level.. so I wanna move all-in-one ? By pressing shift/control for the mouse drag?
[2013-06-10 17:35:10]
This depends. Are these Stop Attached Orders and was the Stop set to the All OCO Groups OCO Group?
[2013-06-10 18:00:48]
cross - Posts: 70
I have 3 targets (scaling out). There are Attached Stops assigned to their target counterparts (OCO Group 1..3, moving to BE and trailing for the 3rd position).
As I see I can use
- one stop for all targets (All OCO Groups) OR
- same number of stops as targets (OCO Group 1..x)
but cannot mix both.
After some move the remaining stops stay at the same level and I expect to move them manually all-in-one (occasionally) but suddenly realize that I move only one of the stops at a time.
I understand that this is not an error but I'm looking for some ease of clicks :)
Thanks!
