Date/Time: Mon, 28 Oct 2024 08:57:54 +0000
Number Bars Vertical line coloring
View Count: 879
[2015-07-19 03:26:29] |
User726098 - Posts: 23 |
Hello, I'm currently trying to configure number bars on the chart. Is it possible to have next to the bars, a vertical line telling you weather it is an "up" set of bars and "down" set of bars. I've seen images of number bars, where they have this set of vertical bars next to it. Basically telling you it's an up candle or down candle after it prints whether using ticks, minutes, etc. I've tried to set numerous settings in the study but can't seem to find this feature. Only thing I seem to get is the arrow on close/open or bar on close/open. |
[2015-07-19 04:42:36] |
User60518 - Posts: 106 |
you need to choose the colour you want to use in the Open Marker / Up Box and Down box colours in the number bar settings
Date Time Of Last Edit: 2015-07-19 04:43:00
[2015-07-21 04:09:05] |
Here is the documentation we have prepared for how to do this: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#DrawingOpenToCloseBoxes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
