Date/Time: Sat, 21 Dec 2024 17:56:10 +0000
TPO POC Width
View Count: 950
[2015-07-18 06:04:58]
Dom7364 - Posts: 257
Supposed to be able to change the width of the POC for the TPO but it doesn't change regardless of changes made in Study settings.
[2015-07-18 06:39:24]
This is not completely clear for us. Are you referring to the extension line?
What are you setting the width to?
[2015-07-18 07:41:31]
Actual width of the POC line. TPO Chart study, settings, POC visible, width ..
[2015-07-18 08:10:55]
Refer to the documentation here about this:
http://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#ColorAndWidthSettings
You must not be setting this through the correct Subgraph. It is 17.
Date Time Of Last Edit: 2015-07-18 08:11:25
