Date/Time: Sun, 04 Oct 2026 21:14:57 +0000
Connection status and compact tool values menu V1269
View Count: 1172
| [2015-07-15 15:04:33] |
| ertrader - Posts: 698 |
Hi Support...maybe I'm missing something with the new design: 1) With 1269, how can I tell connection status (red/green)? 2) How to set up horizontal rather than vertical like the prior toolbar was designed? 3) The prior horizontal toolbar design would stay with the chart when moved or resized. The compact tool values window does not. To avoid repositioning the compact tool values window for each chart (around 25-30) are the only options to rarely move charts around or leave them all maximized? Item 1 is more important than 2 and 3. For now, I will leave all my charts maximized and tab between them so the compact tool values window is in a consistent location. Thanks Date Time Of Last Edit: 2015-07-15 15:17:16
| [2015-07-15 15:26:10] |
For 1 and 2 above I found another post with your updated documentation. Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Still have question on 3. Thanks Date Time Of Last Edit: 2015-07-15 15:29:14
| [2015-07-15 17:15:19] |
3. We will see about automatically moving the Compact Tool Values Window when a chart is moved. This should not be a problem.
