Date/Time: Wed, 14 Oct 2026 10:03:23 +0000
Breakeven (BE) button
View Count: 1508
| [2015-07-15 04:30:58] |
| nicktrader - Posts: 816 |
Quite often I open a second (or third) Order in one trade and later I'd like to use the BE button for both orders but it didn't work correctly. Example: Open a Buy Order on the price of 1000. A little later I open a second buy order 5 ticks lower. Price is running to 1005. Now I'd like to go BE for both orders (BE offset setting = +2). Only the last order runs to BE. Is there a way that both orders are running to BE? |
| [2015-07-15 05:51:23] |
We did not really think about this kind of scenario. The way that it works currently, is the Stop Attached Order nearest the current market price is moved to the breakeven level when using the Move to Breakeven (BE) button.
