Date/Time: Mon, 28 Oct 2024 08:57:52 +0000
Chart loading time
View Count: 1087
[2015-07-14 16:58:26] |
Hieronymus - Posts: 51 |
I have a fast computer and SSD drive etc. To load a different time frame on my openEcry forex charts takes a second, it's very fast. To load a different time frame on the forex data through FXCM takes much longer. Is there a good reason for this? I've tried it on charts with indicators and naked charts, with the same results.
[2015-07-14 17:51:30] |
Solved. I just downloaded a different version and so far it seems to have fixed the problem. |
[2015-07-14 17:56:38] |
This is because there is a lot more data loaded in the chart. You can reduce the Chart >> Chart Settings >> Days to Load setting to speed this up. Refer to help topic 30.1: https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.1 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-14 23:38:18] |
I did try that as well and have read that file. Thanks though. It's solved with using a different Sierra instance.
Date Time Of Last Edit: 2015-07-14 23:38:47
[2015-07-15 00:42:57] |
OK.
[2015-07-21 16:49:49] |
Somehow it's happened again. It was fine for a few days and now the load time for any time frame takes a longer time again. If I get rid of my Sierra3.cfg, chart load time goes back to very fast. I have only 30 days loaded on the chart and it doesn't matter if its a blank chart or filled with stuff.
[2015-07-21 17:55:15] |
Refer to help topics 30.1, 30.8, 30.12: Http://www.sierrachart.com/index.php?page=doc/helpdetails30.html It is completely unnecessary to delete the Sierra3.CFG file. That is not the solution. When you delete that file it will change the Intraday Data Storage Time Unit 1 second which will decrease the time to download historical Intraday data and also load chart data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-21 17:57:46
[2015-07-21 18:35:44] |
Solved.. thank you.
