Date/Time: Fri, 22 Nov 2024 23:42:45 +0000
default sierra data feed
View Count: 1826
[2013-06-09 06:00:45]
User34796 - Posts: 8
I attempted to log into a seperate data feed that was unsuccessful. What are the default data feed settings? Thanks
[2013-06-09 08:22:38]
Please post a copy of the Message Log, by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
[2013-06-09 13:14:23]
Software version: 983 | 2013-06-09 13:02:48
Current Service Package: 5 | 2013-06-09 13:02:48
Usage end date: 2013-12-15 | 2013-06-09 13:02:48
Sierra Chart Historical Data Service is included. | 2013-06-09 13:02:48
Active service: FXCM Data | 2013-06-09 13:02:48
Time Zone: +00:00:00 (UTC+00) | 2013-06-09 13:02:48
2013-06-09 09:02:48 Local computer clock time | 2013-06-09 13:02:48
2013-06-09 13:02:48 GMT time | 2013-06-09 13:02:48
2013-06-09 13:02:48 Time zone adjusted time | 2013-06-09 13:02:48
Time difference to server time: 0 seconds. | 2013-06-09 13:02:48
Program path: C:\SierraChart\ | 2013-06-09 13:02:48
Data Files path: C:\SierraChart\Data\ | 2013-06-09 13:02:48
OS Version Number: 6.1 | 2013-06-09 13:02:48
Connecting to the FXCM Trading service. | 2013-06-09 13:02:55
FXCM connection status changed: Connecting | 2013-06-09 13:02:56
FXCM connection status changed: Disconnected | 2013-06-09 13:02:56
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:02:56
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:02:56
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:02:56
Disconnected from the FXCM trade engine. | 2013-06-09 13:02:56
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:02:56
Connecting to the FXCM Trading service. | 2013-06-09 13:03:01
FXCM connection status changed: Connecting | 2013-06-09 13:03:02
FXCM connection status changed: Disconnected | 2013-06-09 13:03:02
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:03:02
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:03:02
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:03:02
Disconnected from the FXCM trade engine. | 2013-06-09 13:03:02
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:03:02
Connecting to the FXCM Trading service. | 2013-06-09 13:03:07
FXCM connection status changed: Connecting | 2013-06-09 13:03:07
FXCM connection status changed: Disconnected | 2013-06-09 13:03:08
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:03:08
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:03:08
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:03:08
Disconnected from the FXCM trade engine. | 2013-06-09 13:03:08
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:03:08
Connecting to the FXCM Trading service. | 2013-06-09 13:03:13
FXCM connection status changed: Connecting | 2013-06-09 13:03:13
FXCM connection status changed: Disconnected | 2013-06-09 13:03:13
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:03:13
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:03:13
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:03:13
Disconnected from the FXCM trade engine. | 2013-06-09 13:03:13
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:03:13
Connecting to the FXCM Trading service. | 2013-06-09 13:03:18
FXCM connection status changed: Connecting | 2013-06-09 13:03:18
FXCM connection status changed: Disconnected | 2013-06-09 13:03:19
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:03:19
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:03:19
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:03:19
Disconnected from the FXCM trade engine. | 2013-06-09 13:03:19
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:03:19
Connecting to the FXCM Trading service. | 2013-06-09 13:03:24
FXCM connection status changed: Connecting | 2013-06-09 13:03:24
FXCM connection status changed: Disconnected | 2013-06-09 13:03:24
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:03:24
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:03:25
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:03:25
Disconnected from the FXCM trade engine. | 2013-06-09 13:03:25
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:03:25
Connecting to the FXCM Trading service. | 2013-06-09 13:03:30
FXCM connection status changed: Connecting | 2013-06-09 13:03:30
FXCM connection status changed: Disconnected | 2013-06-09 13:03:30
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:03:30
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:03:30
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:03:30
Disconnected from the FXCM trade engine. | 2013-06-09 13:03:30
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:03:30
Connecting to the FXCM Trading service. | 2013-06-09 13:03:35
FXCM connection status changed: Connecting | 2013-06-09 13:03:35
FXCM connection status changed: Disconnected | 2013-06-09 13:03:36
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:03:36
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:03:36
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:03:36
Disconnected from the FXCM trade engine. | 2013-06-09 13:03:36
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:03:36
Connecting to the FXCM Trading service. | 2013-06-09 13:03:41
FXCM connection status changed: Connecting | 2013-06-09 13:03:41
FXCM connection status changed: Disconnected | 2013-06-09 13:03:41
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:03:41
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:03:41
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:03:41
Disconnected from the FXCM trade engine. | 2013-06-09 13:03:41
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:03:41
Connecting to the FXCM Trading service. | 2013-06-09 13:03:46
FXCM connection status changed: Connecting | 2013-06-09 13:03:46
FXCM connection status changed: Disconnected | 2013-06-09 13:03:47
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:03:47
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:03:47
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:03:47
Disconnected from the FXCM trade engine. | 2013-06-09 13:03:47
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:03:47
Connecting to the FXCM Trading service. | 2013-06-09 13:03:52
FXCM connection status changed: Connecting | 2013-06-09 13:03:52
FXCM connection status changed: Disconnected | 2013-06-09 13:03:53
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:03:53
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:03:53
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:03:53
Disconnected from the FXCM trade engine. | 2013-06-09 13:03:53
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:03:53
Connecting to the FXCM Trading service. | 2013-06-09 13:03:58
FXCM connection status changed: Connecting | 2013-06-09 13:03:58
FXCM connection status changed: Disconnected | 2013-06-09 13:03:58
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:03:58
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:03:58
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:03:58
Disconnected from the FXCM trade engine. | 2013-06-09 13:03:58
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:03:58
Connecting to the FXCM Trading service. | 2013-06-09 13:04:03
FXCM connection status changed: Connecting | 2013-06-09 13:04:03
FXCM connection status changed: Disconnected | 2013-06-09 13:04:04
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:04:04
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:04:04
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:04:04
Disconnected from the FXCM trade engine. | 2013-06-09 13:04:04
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:04:04
Connecting to the FXCM Trading service. | 2013-06-09 13:04:09
FXCM connection status changed: Connecting | 2013-06-09 13:04:09
FXCM connection status changed: Disconnected | 2013-06-09 13:04:09
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:04:09
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:04:09
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:04:09
Disconnected from the FXCM trade engine. | 2013-06-09 13:04:09
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:04:09
Connecting to the FXCM Trading service. | 2013-06-09 13:04:14
FXCM connection status changed: Connecting | 2013-06-09 13:04:15
FXCM connection status changed: Disconnected | 2013-06-09 13:04:15
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:04:15
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:04:15
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:04:15
Disconnected from the FXCM trade engine. | 2013-06-09 13:04:15
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:04:15
Connecting to the FXCM Trading service. | 2013-06-09 13:04:20
FXCM connection status changed: Connecting | 2013-06-09 13:04:20
FXCM connection status changed: Disconnected | 2013-06-09 13:04:21
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:04:21
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:04:21
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:04:21
Disconnected from the FXCM trade engine. | 2013-06-09 13:04:21
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:04:21
Connecting to the FXCM Trading service. | 2013-06-09 13:04:26
FXCM connection status changed: Connecting | 2013-06-09 13:04:26
FXCM connection status changed: Disconnected | 2013-06-09 13:04:26
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:04:26
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:04:26
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:04:26
Disconnected from the FXCM trade engine. | 2013-06-09 13:04:26
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:04:26
Connecting to the FXCM Trading service. | 2013-06-09 13:04:31
FXCM connection status changed: Connecting | 2013-06-09 13:04:31
FXCM connection status changed: Disconnected | 2013-06-09 13:04:32
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:04:32
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:04:32
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:04:32
Disconnected from the FXCM trade engine. | 2013-06-09 13:04:32
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:04:32
Connecting to the FXCM Trading service. | 2013-06-09 13:04:37
FXCM connection status changed: Connecting | 2013-06-09 13:04:37
FXCM connection status changed: Disconnected | 2013-06-09 13:04:37
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:04:37
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:04:37
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:04:37
Disconnected from the FXCM trade engine. | 2013-06-09 13:04:37
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:04:37
Connecting to the FXCM Trading service. | 2013-06-09 13:04:42
FXCM connection status changed: Connecting | 2013-06-09 13:04:43
FXCM connection status changed: Disconnected | 2013-06-09 13:04:43
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:04:43
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:04:43
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:04:43
Disconnected from the FXCM trade engine. | 2013-06-09 13:04:43
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:04:43
Connecting to the FXCM Trading service. | 2013-06-09 13:04:48
FXCM connection status changed: Connecting | 2013-06-09 13:04:48
FXCM connection status changed: Disconnected | 2013-06-09 13:04:49
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:04:49
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:04:49
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:04:49
Disconnected from the FXCM trade engine. | 2013-06-09 13:04:49
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:04:49
Connecting to the FXCM Trading service. | 2013-06-09 13:04:54
FXCM connection status changed: Connecting | 2013-06-09 13:04:54
FXCM connection status changed: Disconnected | 2013-06-09 13:04:54
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:04:54
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:04:54
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:04:54
Disconnected from the FXCM trade engine. | 2013-06-09 13:04:54
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:04:54
Connecting to the FXCM Trading service. | 2013-06-09 13:04:59
FXCM connection status changed: Connecting | 2013-06-09 13:04:59
FXCM connection status changed: Disconnected | 2013-06-09 13:05:00
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:05:00
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:05:00
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:05:00
Disconnected from the FXCM trade engine. | 2013-06-09 13:05:00
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:05:00
Connecting to the FXCM Trading service. | 2013-06-09 13:05:05
FXCM connection status changed: Connecting | 2013-06-09 13:05:05
FXCM connection status changed: Disconnected | 2013-06-09 13:05:05
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:05:05
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:05:05
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:05:05
Disconnected from the FXCM trade engine. | 2013-06-09 13:05:05
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:05:05
Connecting to the FXCM Trading service. | 2013-06-09 13:05:10
FXCM connection status changed: Connecting | 2013-06-09 13:05:11
FXCM connection status changed: Disconnected | 2013-06-09 13:05:11
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:05:11
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:05:11
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:05:11
Disconnected from the FXCM trade engine. | 2013-06-09 13:05:11
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:05:11
Connecting to the FXCM Trading service. | 2013-06-09 13:05:16
FXCM connection status changed: Connecting | 2013-06-09 13:05:16
FXCM connection status changed: Disconnected | 2013-06-09 13:05:17
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:05:17
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:05:17
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:05:17
Disconnected from the FXCM trade engine. | 2013-06-09 13:05:17
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:05:17
Connecting to the FXCM Trading service. | 2013-06-09 13:05:22
FXCM connection status changed: Connecting | 2013-06-09 13:05:22
FXCM connection status changed: Disconnected | 2013-06-09 13:05:22
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:05:22
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:05:22
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:05:22
Disconnected from the FXCM trade engine. | 2013-06-09 13:05:22
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:05:22
Connecting to the FXCM Trading service. | 2013-06-09 13:05:27
FXCM connection status changed: Connecting | 2013-06-09 13:05:27
FXCM connection status changed: Disconnected | 2013-06-09 13:05:28
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:05:28
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:05:28
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:05:28
Disconnected from the FXCM trade engine. | 2013-06-09 13:05:28
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:05:28
Connecting to the FXCM Trading service. | 2013-06-09 13:05:33
FXCM connection status changed: Connecting | 2013-06-09 13:05:33
FXCM connection status changed: Disconnected | 2013-06-09 13:05:33
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:05:33
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:05:33
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:05:33
Disconnected from the FXCM trade engine. | 2013-06-09 13:05:33
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:05:33
Connecting to the FXCM Trading service. | 2013-06-09 13:05:38
FXCM connection status changed: Connecting | 2013-06-09 13:05:38
FXCM connection status changed: Disconnected | 2013-06-09 13:05:39
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:05:39
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:05:39
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:05:39
Disconnected from the FXCM trade engine. | 2013-06-09 13:05:39
Will reconnect to the server in 3 minutes. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:05:39
File >> Disconnect selected. | 2013-06-09 13:06:19
Disconnected from the FXCM trade engine. | 2013-06-09 13:06:19
Connecting to the FXCM Trading service. | 2013-06-09 13:06:22
FXCM connection status changed: Connecting | 2013-06-09 13:06:22
FXCM connection status changed: Disconnected | 2013-06-09 13:06:23
FXCM Trading error message: Login failed. Incorrect user name or password | 2013-06-09 13:06:23
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:06:23
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:06:23
Disconnected from the FXCM trade engine. | 2013-06-09 13:06:23
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:06:23
File >> Disconnect selected. | 2013-06-09 13:06:28
Disconnected from the FXCM trade engine. | 2013-06-09 13:06:28
Active service: FXCM Data | 2013-06-09 13:09:33
Connecting to the FXCM Trading service. | 2013-06-09 13:09:40
FXCM connection status changed: Connecting | 2013-06-09 13:09:40
FXCM connection status changed: Disconnected | 2013-06-09 13:09:40
FXCM Trading error message: The specified user or connection doesn't exist. | 2013-06-09 13:09:40
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:09:40
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:09:40
Disconnected from the FXCM trade engine. | 2013-06-09 13:09:40
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:09:40
Connecting to the FXCM Trading service. | 2013-06-09 13:09:45
FXCM connection status changed: Connecting | 2013-06-09 13:09:45
FXCM connection status changed: Disconnected | 2013-06-09 13:09:45
FXCM Trading error message: The specified user or connection doesn't exist. | 2013-06-09 13:09:45
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:09:45
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:09:45
Disconnected from the FXCM trade engine. | 2013-06-09 13:09:45
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:09:45
Connecting to the FXCM Trading service. | 2013-06-09 13:09:50
FXCM connection status changed: Connecting | 2013-06-09 13:09:50
FXCM connection status changed: Disconnected | 2013-06-09 13:09:50
FXCM Trading error message: The specified user or connection doesn't exist. | 2013-06-09 13:09:50
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:09:50
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:09:50
Disconnected from the FXCM trade engine. | 2013-06-09 13:09:51
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:09:51
Connecting to the FXCM Trading service. | 2013-06-09 13:09:56
FXCM connection status changed: Connecting | 2013-06-09 13:09:56
FXCM connection status changed: Disconnected | 2013-06-09 13:09:56
FXCM Trading error message: The specified user or connection doesn't exist. | 2013-06-09 13:09:56
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:09:56
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:09:56
Disconnected from the FXCM trade engine. | 2013-06-09 13:09:56
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:09:56
Connecting to the FXCM Trading service. | 2013-06-09 13:10:01
FXCM connection status changed: Connecting | 2013-06-09 13:10:01
FXCM connection status changed: Disconnected | 2013-06-09 13:10:01
FXCM Trading error message: The specified user or connection doesn't exist. | 2013-06-09 13:10:01
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:10:01
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:10:01
Disconnected from the FXCM trade engine. | 2013-06-09 13:10:01
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:10:01
Connecting to the FXCM Trading service. | 2013-06-09 13:10:06
FXCM connection status changed: Connecting | 2013-06-09 13:10:06
FXCM connection status changed: Disconnected | 2013-06-09 13:10:06
FXCM Trading error message: The specified user or connection doesn't exist. | 2013-06-09 13:10:06
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:10:06
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:10:06
Disconnected from the FXCM trade engine. | 2013-06-09 13:10:06
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:10:06
Connecting to the FXCM Trading service. | 2013-06-09 13:10:11
FXCM connection status changed: Connecting | 2013-06-09 13:10:12
FXCM connection status changed: Disconnected | 2013-06-09 13:10:12
FXCM Trading error message: The specified user or connection doesn't exist. | 2013-06-09 13:10:12
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:10:12
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:10:12
Disconnected from the FXCM trade engine. | 2013-06-09 13:10:12
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:10:12
Connecting to the FXCM Trading service. | 2013-06-09 13:10:17
FXCM connection status changed: Connecting | 2013-06-09 13:10:17
FXCM connection status changed: Disconnected | 2013-06-09 13:10:17
FXCM Trading error message: The specified user or connection doesn't exist. | 2013-06-09 13:10:17
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:10:17
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:10:17
Disconnected from the FXCM trade engine. | 2013-06-09 13:10:17
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:10:17
File >> Disconnect selected. | 2013-06-09 13:10:21
Disconnected from the FXCM trade engine. | 2013-06-09 13:10:21
Connecting to the FXCM Trading service. | 2013-06-09 13:11:38
FXCM connection status changed: Connecting | 2013-06-09 13:11:38
FXCM connection status changed: Disconnected | 2013-06-09 13:11:39
FXCM Trading error message: The specified user or connection doesn't exist. | 2013-06-09 13:11:39
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-09 13:11:39
To prevent further connection attempts, select File >> Disconnect. | 2013-06-09 13:11:39
Disconnected from the FXCM trade engine. | 2013-06-09 13:11:39
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-09 13:11:39
[2013-06-09 20:08:33]
Select Global Settings >> Data/Trade Service Settings. In the Service box at the top select "SC Forex Data (FXCM)".
Here is the complete documentation:
http://www.sierrachart.com/index.php?l=doc/SCRealTimeFOREX.php
Date Time Of Last Edit: 2013-06-09 20:08:52
