Date/Time: Sat, 21 Dec 2024 17:46:46 +0000
[User Discussion] - Enable Spreadsheet Auto Trading Based on Condition or Time
View Count: 766
[2015-07-14 05:37:13] |
djcurcio - Posts: 236 |
I would like to turn on and off Auto trading at a specific time. For example: =TurnOnAutoTrading = (j41-int(j41))>timevalue("23:28:00")
[2015-07-14 13:56:19] |
Sawtooth - Posts: 4141 |
You can enable/disable autotrading with a y/n in cell H2, e.g.: =OR(J41-INT(J41)<TIMEVALUE(J1),J41-INT(J41)>TIMEVALUE(J2),H2<>"y") where: the above formula is in J28 the start time is in J1 the end time is in J2. If your enable window crosses midnight: use this instead: =OR(AND(J41-INT(J41)<TIMEVALUE(J1),J41-INT(J41)>TIMEVALUE(J2)),H2<>"y") |
