Date/Time: Sat, 21 Dec 2024 17:49:35 +0000
Unable to load 4 second chart
View Count: 839
[2015-07-13 15:03:46]
peaceland - Posts: 95
I have been working with seconds charts. Most of them load. The 4 second chart appears to be missing data, even though it is attempting to load 170 days worth of data. All the other seconds charts I have tried seem to load fine, but the 4 second chart on NzdUsd does not seem to work. Please advise.
[2015-07-13 16:28:11]
The 2 second chart also will not load any more than today's data.
[2015-07-13 16:49:35]
For help with missing data, refer to this section here:
https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#MissingOrIncompleteIntradayChartData
This is too vague for us to help with. Please be very precise as to exactly what the problem is. Specifically what are you seeing.
[2015-07-13 18:53:13]
Started from scratch and downloaded the data without any studies, then added studies, and it seems to be working ok now... thank you!
[2015-07-13 23:32:43]
It seems I am only able to load "so many" seconds charts. Is there a limit? After about 3 or 4 charts, they start showing up black, and will not allow me to do anything with them. I have to start all over.
Like if I want to load 1s, 2s, 3s, 4s, 5s, etc. it won't allow me to do that many charts at that resolution. Is there a limit?
[2015-07-14 00:03:19]
What we are suspecting is that you are running out of memory. If this is the case, the Message Log will indicate this. The memory limit will be about 3 GB. You can overcome this by installing multiple copies of Sierra Chart.
Go to Chart >> Chart Settings and set the Days to Load to a smaller number like 5 or less.
For example, for a 1 second per bar chart, you really do not want to load any more than 2 or 3 days of data maximum. You can control the date range to load through the Chart Settings window.
Date Time Of Last Edit: 2015-07-14 02:03:45
[2015-07-14 01:55:45]
Ok, I'll try running another instance. Seems strange though, because I an load a lot more days with minute charts no problem.
