Date/Time: Sat, 21 Dec 2024 17:47:19 +0000
Tool Config shortcuts not working
View Count: 1109
[2015-07-12 12:23:36] |
User742717 Mike - Posts: 86 |
Hi, I have a few tool configs set. I've set A,B,C,D to each tool config via shortcut editor but nothing activates any tool configs. |
[2015-07-12 19:56:08] |
Are you able to select a particular Tool Configuration when you manually select it through Tools >>Current Tool Configuration? If so, then those particular keyboard shortcuts are not working for unknown reasons. We would not know why and cannot help with that. Keyboard shortcuts can sometimes not work properly for reasons which are not within our control. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-13 00:43:53] |
Disregard, it works
Date Time Of Last Edit: 2015-07-13 01:24:18
[2015-07-13 02:05:38] |
This is good. Another thing that came to mind is that to be able to select a particular Tool Configuration you need to have a drawing tool selected on the Tools menu. So make sure something like Tools >> Line is checked on the menu.
