Date/Time: Mon, 05 Oct 2026 00:55:04 +0000
Trouble pulling SMI from other charts
View Count: 1692
[2015-07-10 17:47:40]
User424542 - Posts: 6
I'm building a bot that needs to pull the SMI value from the Stochastic Momentum Indicator of two other charts. Chart 1 and chart 3. My bot sits on chart 2. On each chart, the SMI is ID: 1.
From chart 2 where the bot sits, it can easily pull the correct value using the following code:
SCFloatArray StudyPosiedon;
sc.GetStudyArrayFromChartUsingID(2, 1, 0, StudyPosiedon);
When I replace the 2 with a 1 or 3 (yes, I checked the charts to make sure of the chart #s), chart 1 gave nothing, and chart 3 gave values that don't match anything I can see. Definitely not an ES price value, and I cant see any values on the SMI that report a value of 90.097.
Any idea what is wrong in my code? Is there a better way to pull that value from other charts?
[2015-07-10 17:58:11]
You need to be aware that the array sizes are different with charts 1 and 3 compared to 2, so you need to be able to find the corresponding index in the study Subgraph array you are getting, which corresponds to chart 2.
Refer to the documentation here:
Referencing Other Time Frames and Symbols When Using the ACSIL
Date Time Of Last Edit: 2015-07-10 18:08:53
[2015-07-10 18:02:33]
You mean the subgraph array inside the SMI? Playing around with it a bit, I figured out that it is subgraph 0.
[2015-07-10 18:09:08]
Yes. This is correct.
[2015-07-10 18:17:47]
I just need to know the last 3 values of the SMI of other charts. I don't actually need to draw it. What should I use to just retrieve those values for use in calculations?
[2015-07-10 18:28:34]
I've updated the code to the following, trying to capture values from another chart. It sees them on the study calculation when I hit Apply, but than proceeds to give nothing but 0s in the message log.
  sc.GetStudyArrayFromChartUsingID(1, 2, 0, StudyPosiedon);
  float fishFood = StudyPosiedon[sc.Index];
  Posiedon3[sc.Index] = StudyPosiedon[sc.Index];
  SCString BufferOne;
  BufferOne.Format("Current value: %f", fishFood);
  sc.AddMessageToLog(BufferOne, 0);
Date Time Of Last Edit: 2015-07-10 18:28:49
[2015-07-10 18:56:27]
Here is code to get the very last value of the study Subgraph:
if (StudyPosiedon.GetArraySize() == 0)
return;
float LastValue = StudyPosiedon[StudyPosiedon.GetArraySize() -1];
