Date/Time: Mon, 23 Dec 2024 03:18:03 +0000
[User Discussion] - Question about hotkeys and chart
View Count: 1008
[2015-07-10 12:59:59]
User90998 - Posts: 6
Hello!
1) Can I assign a hotkeys command "OCO Buy Stop Sell Stop (Auto-Set)" and "Send Attached Orders By Position"?
2) Does the SierraChart to creat on the same chart two different timeframe charts at the same time? For example, is it possible to create 5M chart, each 5M Candlestick bar contains 5 pieces 1M candlestick bar?
Thank you and sorry for my english).
[2015-07-10 17:50:47]
1. Keyboard shortcuts are not supported for these trading commands. You need to use the Chart Shortcut menu displayed by right clicking on the chart to select these commands. If they are not listed, then you need to add them through Global Settings >> Customize Chart Trade Menu.
2. Something like this can be done by using the Study/Price Overlay study. Refer to this help topic for instructions:
https://www.sierrachart.com/index.php?page=doc/helpdetails28.html
[2015-09-10 17:35:08]
User322934 - Posts: 1
is possible to add function execute OCO orders (Auto-Set) from market price, not only where is actual position of crosshair?
