Date/Time: Tue, 26 Nov 2024 13:01:19 +0000
User Email Question - Proxy
View Count: 3029
[2013-06-07 23:58:18]
Sierra Chart - Max - Posts: 5731
our corporate proxy is using authentification mode. So in properties of proxy connection I must somewhere enter my proxy login and password to pass throuh our proxy. But I cant find in SC any place where I can setup this data.
In yours recomedations from http://www.sierrachart.com/index.php?l=doc/LoginInstructions.php#LoginProblems (2.4) I also cant find anything for fix my issue.
Can you help me to setup proper settings to pass trouht proxy with autentification?
Here is log from SC with my unsuccessful login:
SC Forex Data (FXCM): Connecting to the market data server. | 2013-06-07 10:23:32
Using server: ds4.sierracharts.com, port 443 | 2013-06-07 10:23:32
SC Forex Data (FXCM) - Local market data port: 0 | 2013-06-07 10:23:32
Error connecting socket: Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-06-07 10:23:33
SC Forex Data (FXCM): Lost the connection to the server. | 2013-06-07 10:23:33
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-06-07 10:23:33
To prevent further connection attempts, select File >> Disconnect. | 2013-06-07 10:23:33
SC Forex Data (FXCM): Disconnected from the market data server. | 2013-06-07 10:23:33
Will reconnect to the server in 5 seconds. Select File >> Disconnect to prevent further connection attempts. | 2013-06-07 10:23:33
File >> Disconnect selected. | 2013-06-07 10:23:37
SC Forex Data (FXCM): Disconnected from the market data server. | 2013-06-07 10:23:37
Sierra Chart Support
[2013-06-08 00:22:49]
Other than for logging into Sierra Chart itself, a proxy is not supported. So you cannot connect to the market data feed over a proxy. Must be a direct connection.
[2013-06-08 06:42:30]
zencoder - Posts: 10
I see... But in SC I can setup proxy connection parameters (proxy address an port) in initial window before login - http://www.sierrachart.com/images/LoginInstructions_MainLoginWindow.png
May be it will be possible to extend it and add two new fields (proxy login and password)? If they will be filled - SC "transfer" they to the proxy during login.
Autentification is one of the standart method of accessing proxies, and it wil be great if SC will support it ;)
Date Time Of Last Edit: 2013-06-08 06:43:17
[2013-06-10 22:36:42]
Sierra Chart does not support a proxy server for a market data feed connection. Only for the HTTP connections. And the market data feed does not use this type of connection.
We will have to look at this later on, but will not be for a while.
Date Time Of Last Edit: 2013-06-10 22:37:00
[2013-06-10 22:50:12]
TastyRisk - Posts: 119
this software http://www.proxifier.com/
[2013-06-10 23:13:58]
Thank you for this. But if they use that software would they have to be able to change the server address for the market data feed they are connecting to, within Sierra Chart?
In the case of the Sierra Chart market data feeds, this cannot be done.
[2013-06-10 23:18:30]
One solution would be use http tunnel and OpenVPN to transparently bypass the proxy as is explained here:
http://exiledmind.net/vpn-tunnel/
Note, that this solution would require that you have access to a machine that is outside of the proxy. a low cost VPS works great.
Date Time Of Last Edit: 2013-06-10 23:20:04
[2013-06-11 07:14:20]
Solution here http://www.proxifier.com/index.htm
In Profile / Proxy Servers - set up yours proxy server adsress, port, and(!!!) proxy type, authentification login/password, and create 2 rules:
1) Default rule: Action - Direct (all applications trnsparently pass trought proxifier
2) Rule for SierraChart: Target Hosts - Any, Target Port - Any, Action - Proxy HTTPS
After this manipulations I obtain live price in SC and green status :)
[2013-06-11 08:53:45]
The OP needed use a proxy. Not bypass a proxy.
