Date/Time: Thu, 17 Sep 2026 14:07:31 +0000
"Currency Value (C) & Ticks - Ignore Quantity (t)" displays incorrect tick value d
View Count: 1095
| [2015-07-09 17:11:45] |
| SviCh - Posts: 40 |
I select "Currency Value (C) & Ticks - Ignore Quantity (t)" in Chart Settings. Then I have C and t value for current position calculated correctly. But t value for DPL is calculated wrongly. |
| [2015-07-09 23:15:27] |
There really is no way for the Daily/Profit Loss to reliably ignore the quantity in all cases. So in the next version, the Daily Profit/Loss will consider the quantity and display the suffix T.
