Date/Time: Wed, 12 Mar 2025 05:18:17 +0000
[Programming Help] - bar index of ACSIL created drawing
View Count: 3553
[2015-07-08 19:03:32] |
User231363 - Posts: 31 |
I am creating rays from ACSIL at various bars and price levels. I would like to have the study delete the rays that are older than a certain bar index, however I can't figure out how to get this information from existing ray drawings. I have tried GetUserDrawnChartDrawing(), and while it returns the correct Line Number, the .BeginIndex is -1 even though I can see the ray on the chart at the correct bar index. How can I get the bar index number from an existing drawing? thanks. |
[2015-07-09 18:33:54] |
Use this ACSIL array: http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scBaseDateTimeIn to determine a particular Date-Time for that bar index and simply compare that to the Date-Time values of the chart drawing. There are also functions to get a bar index using a date-time value. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-09 19:42:50] |
I know how to work the indexes. The issue is that when I read the ray drawings created by ACSIL, the BlockTradeLine.BeginIndex and BlockTradeLine.BeginDateTime are -1. I'm using this code to create the rays: LastBlockTradeLineBarIndex = sc.Index;
LastBlockTradeLinePrice = currPrice; Tool.Clear(); // reset tool structure for our next use Tool.AddAsUserDrawnDrawing = 1; Tool.ChartNumber = ChartNumberToDrawLines.GetInt(); Tool.DrawingType = DRAWING_HORIZONTAL_RAY; //Tool.DisplayHorizontalLineValue = 1; Tool.LineNumber = LastBlockTradeLineNumUsed; Tool.BeginIndex = sc.Index; Tool.BeginValue = currPrice;// *sc.RealTimePriceMultiplier; //Tool.EndValue = Tool.BeginValue; Tool.Color = RGB(255, 0, 255); // Magenta //Tool.Text = "bid"; Tool.LineStyle = LINESTYLE_DOT; //Tool.LineWidth = 3; Tool.AddMethod = UTAM_ADD_OR_ADJUST; sc.UseTool(Tool); SCString Buffer; Buffer.Format("Created line chart: %d w/line num: %d @ index:%d price:%f", Tool.ChartNumber, Tool.LineNumber, Tool.BeginIndex, Tool.BeginValue); sc.AddMessageToLog(Buffer, 0); ======================================= Code to read the drawing: int chartsFound = sc.UserDrawnChartDrawingExists(targetChartNum, i); if (chartsFound > 0) { BlockTradeLine.Clear(); sc.GetUserDrawnChartDrawing(targetChartNum, DRAWING_RAY, BlockTradeLine, 0); SCDateTime lineTime = BlockTradeLine.BeginDateTime; SCString timeStr = sc.FormatDateTime(lineTime).GetChars(); Buffer.Format(" deleting chart: %d w/line num: %d -> index: %d, price:%f, date:%s", targetChartNum, i, BlockTradeLine.BeginIndex, BlockTradeLine.BeginValue, timeStr); sc.AddMessageToLog(Buffer, 0); =================================== |
[2015-07-10 03:31:21] |
This is an indication that you are not successfully getting the drawing. We have confirmed that both of those variables are set when getting the drawing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-10 03:31:52
[2018-07-15 10:40:06] |
binaryduke - Posts: 378 |
Please could you provide an example of this that successfully returns BeginIndex or BeginDateTime? Testing with the code below still returns a -1 value for the BeginIndex member of the s_UseTool structure yet the BeginValue member of the structure is populated upon the creation of the drawing. I have noted the documentation comment for sc.GetACSDrawingByIndex() that: When a Chart Drawing you are getting is not visible in the current view of the chart, then s_UseTool::BeginIndex, s_UseTool::EndIndex, s_UseTool::ThirdIndex will all equal -1 unless the drawing specified its horizontal positioning using these *Index values when it was added. and in testing the code below specified the horizontal positioning using these Index values. I have further tested by specifying s_UseTool::EndIndex and s_UseTool::ThirdIndex with the same result. //create a drawing s_UseTool MyDrawing; MyDrawing.Clear(); MyDrawing.ChartNumber = sc.ChartNumber; MyDrawing.DrawingType = DRAWING_MARKER; MyDrawing.MarkerType = MARKER_POINT; MyDrawing.MarkerSize = 10; MyDrawing.Color = RGB(255,0,0); MyDrawing.AddMethod = UTAM_ADD_OR_ADJUST; MyDrawing.BeginIndex = sc.Index; MyDrawing.BeginValue = sc.High[sc.Index]; sc.UseTool(MyDrawing); //access the created drawing to obtain the value of its s_UseTool structure members s_UseTool ExistingDrawing; for (int i = 0; i < sc.GetACSDrawingsCount(0, 1); i++) { ExistingDrawing.Clear(); int Result = sc.GetACSDrawingByIndex(0, i, ExistingDrawing, 1); SCString ExistingDrawingInfo; ExistingDrawingInfo.Format("Drawing Index %i GetACSDrawingResult %i BeginIndex %i BeginValue %f", i, Result, ExistingDrawing.BeginIndex, ExistingDrawing.BeginValue); sc.AddMessageToLog(ExistingDrawingInfo, 0); } |
[2018-07-17 19:09:40] |
We will test this.
[2018-07-17 19:50:58] |
There is a problem related to this and it will be resolved in 1783.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-07-17 19:51:07
[2019-10-09 22:23:50] |
lhealey - Posts: 5 |
[quote]How to Capture the Bar Index (date) of a User Drawn Vertical Line[/quote]
I need to capture the date that corresponds to a manually drawn Vertical Line; a line NOT created by ACSIL. I use [b]a single vertical line[/b] to mark the new Earnings Date for each symbol I'm evaluating. These earnings dates vary greatly, but it's an integral part of my analysis. Seems like it should be simple, but I can't seem to find an answer. The latest function I've tried is sc.GetUserDrawnChartDrawing()... but this seems only useful for capturing text. I notice the Anchor text displays the date, so I could use that data or the actual date, the bar index or even another drawing tool if need be. Thanks!!! <a href="http://www.sierrachart.com/image.php?Image=1570659557876.png" target="_blank" rel="noopener noreferrer">http://www.sierrachart.com/image.php?Image=1570659557876.png</a> |
