Date/Time: Mon, 16 Sep 2024 20:20:56 +0000
Open and Close on Price Volume Bars
View Count: 777
[2015-07-08 01:35:08] |
ronghuax - Posts: 12 |
Hi I was trying my hands on price volume bars, but could not see open and close on the bar. Is this supported? I already checked the support page here: http://www.sierrachart.com/index.php?page=doc/doc_PriceGraphTypes.html#PriceVolumeBars, there's no mentioning about this. Thanks |
[2015-07-08 03:27:26] |
To actually see where the Open and Close are, you would need to use Candle Price Volume Bars.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-08 03:36:55
