Date/Time: Mon, 16 Sep 2024 19:35:43 +0000
best and most reliable data oec or rithmic
View Count: 1809
[2015-07-07 23:52:47] |
mrhurley1 - Posts: 7 |
please can you tell me which if oec or rithmic is the best data feed with sierra?
[2015-07-08 03:26:28] |
By far Rithmic is better. Major difference when the market is active, based on user feedback we hear on this Support Board. We do hear about lagging problems with the OEC data feed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-08 17:09:41
[2015-07-08 11:41:12] |
I also have a cts data option, is this better than either? Thanks
[2015-07-08 17:09:02] |
CTS is good. We would not say it is better or worse than Rithmic.
