Date/Time: Mon, 16 Sep 2024 19:18:50 +0000
Can't select live account from Trade window
View Count: 787
[2015-07-07 22:37:44] |
Locomotora - Posts: 14 |
I opened an account with AMP/CQG and i am trying to select the account from the Trade Window Drop Down Menu but it shows only "Sim1". How can i select the live account. Thanks |
[2015-07-07 23:58:26] |
Never mind, I got it fix. Thanks
[2015-07-08 03:17:39] |
For reference you need to disable Trade Simulation Mode: http://www.sierrachart.com/index.php?page=doc/doc_Trading.html#DifferenceBetweenSimAndNonSim Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
