Date/Time: Wed, 05 Feb 2025 13:03:56 +0000
How to copy the Alert Manager to Excel or Notepag
View Count: 1111
[2015-07-07 22:27:19]
CMG - Posts: 179
Hello, How do I download the alert manager to excel. I run a scan but don't seem to find an option to download the info
http://www.sierrachart.com/image.php?l=1436307979790.png
Or any suggestion where I can keep the info?
thnks
[2015-07-08 01:45:23]
What you can do is select all of the lines in the Alerts Log and select Edit >> Copy Selection.
[2015-07-08 17:31:14]
CMG - Posts: 179
Hello, It does not let to select all of them just the first line...Any other idea?
[2015-07-08 17:43:23]
To select all of them, select the first line in the log. Hold the Shift key and then go to the last line and select that.
[2015-07-08 17:56:35]
CMG - Posts: 179
Any plans on improving this feature? an idea if we are just able to output the file to and .xls file, that will be great...have a nice one.
[2015-07-08 18:12:23]
There is 0% chance we would support writing to an Excel file format directly.
But we will add an option to copy the entire log at once to the clipboard.
