Date/Time: Mon, 16 Sep 2024 19:54:17 +0000
Zig zag text under volume profile
View Count: 1127
[2015-07-07 22:15:49] |
User97684 - Posts: 136 |
Please help, I did look through all settings for 'Zig zag' and 'Volume at price' on both charts and they are identical. Why am I getting the swing points text once over the volume bars and once under them? Many thanks ves |
text_visible.png / V - Attached On 2015-07-07 22:14:57 UTC - Size: 128.25 KB - 375 views text_invisible.png / V - Attached On 2015-07-07 22:15:09 UTC - Size: 137.63 KB - 337 views |
[2015-07-08 03:25:26] |
Refer to this section about the drawing order of Chart Drawings (Zig Zag text) relative to the graphs: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
