Date/Time: Mon, 16 Sep 2024 19:49:57 +0000
Different colors for trading dom
View Count: 738
[2015-07-07 19:44:15] |
User104164 - Posts: 19 |
Hi, I trade with two trading doms for two different strategies for same instrument. It gets confusing due to same color. Is there anyway I can change the color of one of them? Thanks. |
[2015-07-07 20:48:44] |
Yes. You can change the colors individually for each of them through Chart >> Graphics Settings. This is explained here: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizingGraphics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-07 21:13:40] |
thanks.
