Date/Time: Mon, 16 Sep 2024 19:08:10 +0000
Charts changed with new prerelease, can't get back to previous charts
View Count: 834
[2015-07-07 15:27:10] |
Willson - Posts: 176 |
Was using prerelease 1268. Upgraded to latest prrerelease last night. Lost my tools menu and the connect/disconnect menu. So I reverted back to the Full release 1261. Now all charts are missing all overlay indicators. How do I get back to a working system? Regards |
[2015-07-07 15:33:20] |
The Tools menu? The Tools menu is just fine. There could not be a problem with that. Or are you referring to the ToolBar? Follow the instructions here to use a backup Chartbook: http://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#BackupChartbook We have to check on the problem you describe here: Now all charts are missing all overlay indicators.
[2015-07-07 15:53:58] |
I am probably referring to the toolbar. It contains the disconnect/ connect buttons, and numerous tool selection shortcuts and chart time frames.
[2015-07-07 16:11:39] |
Using the backup file restored my missing chart indicators, thanks. Can I update to latest pre release ? with min chance of losing toolbar? |
[2015-07-07 16:23:56] |
It would be best to wait until next week before updating to the prerelease because we are still working on the new ToolBar.
