Date/Time: Mon, 14 Sep 2026 07:11:42 +0000
"Color Bar Based on Alert Condition" applied against study's subgraph?
View Count: 1612
| [2015-07-07 15:25:22] |
| jwick - Posts: 142 |
Can I change the color of a study's subgraph based on an alert condition? I tried using the Color Bar Based on Alert Condition study but it didn't seem to work.
| [2015-07-07 15:50:52] |
Yes you can. This is documented here: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 For this study, refer to the subsection named "Coloring Subgraphs of Other Studies" Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-07 15:51:13
| [2015-07-07 16:24:19] |
Thanks! That worked great.
